I cant make zswatch plugin work in my zbrush 155b demo. I already made subfolder for Zstartup. This
is my folder heirarchy C:\ZBrushDemo_155b\ZStartup\ZPlugs\ZSwatch3. Is the plugin
function lock for zbrush 155 demo?
…with the ZB 1.55b demo :rolleyes:
Pilou
Ok tnxs. French Pilou… Is there any plugins for 1.55b here in the site… where can i find link.
…depend as you want ?
Use the Engine research with “plug in” inside and look date in the results
Pilou
Ps the best is this one Zplace by Cameyo (post #2) (clic on the orange line
You see some examples in my signature :rolleyes:
ZPlugins were a concept introduced with ZBrush 2. There are no plugins for the demo.
There are, however, a good many ZScripts which were written for version 1.55b and work fine with the demo. When looking at any script here at ZBrushCentral, look at the date that it was posted. If the date is prior to March 31, 2004 then the script will run on the demo. If the date is after that, then it is probably for ZBrush 2 and won’t work on the demo.
