Hi Guys, Ive learned recently to use the UV Master but Im having some problems with it. In the first image below there is a part of a project Im working on, in the second and third image are respectively its polygroup subdivisions, which Ive used to make the UV Map represented on the forth image, and the control paint I`ve used to make the UV, but the problem shows up on the fifth image in which appears the sculpting with UVs crated and a check texture map applied to it, but, as you can see, the side areas indicated with the red arrows had not been applied with a texture. The sixth image shows where, in the flatten UV, that part went, and you can notice that it almost disappears! The seventh image shows in a zoom where that part went. It was shrunk in that tiny little piece there!
Anybody could help me solve this problem or have any clue why that happened?
