Help me :<
how to make alphas and strokes with better resolution:qu: :rolleyes:
whenever I try to do, they are deformed :cry:
It would be helpful if you detailed your workflow and even upload a picture or describe your mesh so someone can diagnose your possible problem.
With very little information, I’m guessing one or more of these may be your problem
  • You haven’t sufficiently subdivided your mesh to allow for enough detail
  • You are using the wrong brush and/or brush stroke
  • You haven’t properly set your brush size and/or focal shift to the requirements of the alpha
  • Your z intensity strength is too strong
  • You are stroking too close to the edge of a rounded shape and the stroke is stretching along that edge. Rotate you model to continue and don’t sketch off the edges of curves, however using the Stencil wrap function allows for the alpha to wrap around.
I’m certain there are a number of other possibilities, but without enough info its hard to know what to advise.
