Help, I don´t know how to export correctly zbrush 3.1 projects to Zbrush 3.5
Hi
I need to solve an annoying problem I have right now with Zbrush 3.5 ; and I´m sure I´m not the only one having it.
I need to finish a 3d project I began in Zbrush 3.1, and I need to finish it in Zbrush 3.5 for the technical advantages it gives to the user.
The big problem I face when I open the Zbrush document in the 3.5 version will be known for many people, I suppose. and it is this one: THE MATERIALS.
My 3d model made in zbrush3.1 is shown in the Zbrush 3.5 version without all the materials; it is shown like in was in “render flat mode” but it is in render “preview mode”.
In the “Material” section I press the “Show used”
button and it shows all the different materials I made in the previous zbrush3.1 version now in flat mode, in fact all the materials are shown with the same material name “flat color”; so (and this is very important to have in mind) if I import one of the old zbrush3.1 materials in the zbrush3.5 material section (and I´ve made it, of course) the material is imported correctly but affect to all the different materials I had on my 3d model; because as I said, all the materials are shown with the same material name “flat color” (AND THIS IS THE BIG HORRIBLE PROBLEM); so I finally have my 3d model with all its materials turning to be the just recently imported material.
SO, PLEASE, Is there any way to IMPORT correctly one zbrush 3.1 document/project into ZBRUSH 3.5 ? I think there must be at least one.
Does exist any zbrush3.1 plugin to export 3d models with all his shaders and textures to ZBRUSH 3.5?
Thanks to anybody who can help me
