Help Exporting, Saving, Transfering Curves
Hello I have a question about curves and Zremesher. I have a high poly model that I used decimation master on and then drew curves and used Zremesher in order to correct the topology and quadrify the mesh. I still need to remove polys at this point and I would like to use decimation master again, however it triangulates the mesh and I would have to redraw the curves (because once I used Zremesher my curves were lost on the resulting mesh, and it took some time).
So my question is this is there a way to save curves, or export curves, or transfer curves between similarly shaped models.
Thank you in advance for any help given.
Shamus
If you’ve already used zremesher, and want to reduce the polycount further, you can simply run zremesher again (as many times as you like).
Do it on a copy of your tool so you can project details after zremeshing.
After zremeshing, subdivide it up and project details from your original hi-poly model, or from your decimated copy.
