I’ve been exploring the curve mode recently, and the max points and snapshot seem to be the only ones that i can’t tell what they do. The “max points” option in 4R3 definitely help out putting more instances of the same alpha applied along the curve so that there are no gaps in between when i increase it. However, in R4, it doesn’t do anything whether i put it a low or high value. Usually, the curve step, and curveedit radius, and clicking on the curve to apply the stroke based on view distance is all you need to control how many instances of the alpha are applied. The only problem with this is what if i wanted to apply a big alpha with few instances along a very windy curve. I find i cannot do this, since if i increase the curve step to draw out a windy curve, more instances of the alpha will be applied along the stroke, not less. I was hoping the “max points” option would give me that control.
Apart from this, i have no idea how to use the “snapshot” feature of curve mode.
Thanks.
