headus UVLayout
I’m considering purchasing headus, but I wanted to first see if any of you have had issues using headus with ZBrush. Does headus mess with your point order if you use its Find Symmetry feature? Stuff like that. Thanks!
Incidentally, the the reason I want headus is because of that symmetry feature. As far as I’ve been able to figure, to get symmetrical UVs in 3dsmax, you have to delete half of your mesh, lay out yor UVs, then mirror everything over. That obviously will screw with your point order though, so it’s a no-no for ZBrush. I’ve been watching the videos on the headus website and it looks pretty awesome.
-Dustin
Headus is awesome, get it. It lays out the UV’s and is a deep program, I highly recommend it but it takes some time to lay out the UVs and the program can be frustrating. I haven’t used the symmetry feature because perfect symmetry with UVs isn’t necessary, I don’t imagine UV layout will change the point order.
