Hi, everyone!
Hey there,
I export the videos from ZBrush using the MPEG-4 compression, not the default H.264. I also turn off any data rate limits.
After that I will use Quicktime pro to convert the video to H.264 for better compression.
If you’re not doing this now then that is the first step I would take. Also, you can change the gradient in the background by setting Document: Rate to 0.
Best,
Ryan
Thank you very much, Ryan I will do that and I think it’s a good Idea to buy QTpro.
I bought QTPro once, 2 months later they upgraded Qucktime and my purchase of QTPro was useless unless I purchased QTPro again.
Thanks, zber2 for reporting, I asked a friend of mine yesterday - he said it would be a good idea to disable the updater to avoid this.
