I am having a hard time with several features in zBrush. I am using Z3.2 on a Mac 10.5.8 and am following the zBrush Character Creation book. The Few things I need help with in this book, of course are not working for me. And to make things even trickier the interface of Z3 has changed from when this book was made and from the Z3 interface I am using now. I will start with my first issue
Insert Mesh - does not work. I append the 3D poly mesh I want to use, making sure it has the same amount of subdivisions as the mesh I want to insert it to and then I scale, rotate and position it where I want it. I then clone the tool I want to insert and then delete it from the subtool menu. I then go to geometry>insert mesh and select the recently cloned tool and then nothing happens. I am going step by step in this book with no luck. so Am i missing something?
Pixos, Please help. Or is this and the three other things i am stuck on something I should open a support ticket for? Please let me know.
Thanks
