h-e-l-p! loding an image via textures
im new to 3-d sculpting , so its really basic -
after importing an image through the texture palette im supposed to see it on my object but its not showing
i can see the new texture on the left shelf, but clicking on it provides nothing
im really stuck here, would appriciate any help
Ever since version 3.5, separate textures are now able to be applied to each SubTool. This means that loading it into the Texture palette is not enough because if your model has multiple SubTools ZBrush wouldn’t know which one to apply it to.
After importing your image via the Texture palette, select the desired SubTool and then go to Tool>Texture Map. There, click the thumbnail and select the texture you just loaded.
For more on this topic (and others), see the New Features PDF found in your ZBrush 4\Documentation folder.
thanks. that really helped. :slight_smile: :smiley:
