Is there anyway to set custom angles, like 3/4 views via the grid?
Could do it with image plane plug…set them up wherever.
I’m probably missing it in the docs or something.
A drag if it only works along two axes.
thx
joe
If you have patch 2 for 4R4 installed then you can use Image Plane. It has been updated and Reference Views restored.
Patch 2? Where is it?
How to Update
- (PC Users, Only) Browse to your ZBrush 4R4 folder and delete updater.exe, if present. Do NOT delete ZUpgrader.exe!
- Run ZUpgrader or launch ZBrush and click Zplugin>Auto Update>Check new updates.*
- Follow the on-screen instructions.
- When update completes, launch ZBrush and activate. The ZBrush title bar will now say “ZBrush 4R4 P2”.
*Note: For some users, depending on user permissions and network security, the “Check new updates” button may return a script error. If that happens, simply run ZUpgrader in your ZBrush 4R4 folder.
