Greenhorn Trim Problem
Hi, I need help.
Im sure its the easiest solution.
Please help me.
I am trying to carve a block of mesh to match the blueprints I have set on the grid via draw front-back ect…
But the trim does not leave the mesh uniformly shaped to the trim shape…
How can I acheive a uniform consistent shape accross the entire mesh to match the blueprint on the background?
Video on youtube: https://youtu.be/N6gkBsONbRM
For that kind of shape clipcurve will give better results than trimcurve, even either are not free of problems. Trimcurve deletes the area and creates a fill hole geometry, that is not accurate in curved shapes. Clipcurve pushes the geometry, that will work as long there is not a curved section that overlaps.
Apart of that shadowbox could have more flexibility but you would need to have a very highly subdivided one.
Rather than trying to carve it out like you, I’d probably use a QCyl(half of one) and the ZModeler brush to get the shape close and then enable smoothing as needed.
