Graphire4 issues with Zbrush 3.0
Hi, I’m not sure if anyone can help me with this or not…
I haven’t played with Zbrush 3.0 for a while now and today I decide to finally learn it. I am really enjoying the tutorials I’m finding on this site, and across the web yet I decided that I should be using my tablet for better results.
I am using a Graphire 4 Wacom tablet, and seemingly when I start to glide the pen across the surface I’m working on, it completely disappears…as if I’m erasing the entire sphere, yet when I rotate the object with the pen it has done what it is suppossed to do either adding or taking away.
I’m not sure if there is a setting of sorts in order to make a graphire 4 tablet function correctly with Zbrush or not. I am not having any issues with my mouse at all, so I’m not sure why it would be doing this only when I use the wacom as the pointer.
If anyone has any ideas it would be great to hear so I can use my Wacom with Zbrush.
I attached a pic of what it is doing when I use my wacom…
I’ve seen this problem before in another thread but couldn’t find it for you.
:small_orange_diamond:I would check if you have the latest driver for your Wacom.?
Also check your preferences in your Wacom utilities so nothing seems wrong there. Ex. If you accidentally press the primary button and its function is “erase” ? (just a thought):sunglasses:
Best.
What you are showing is most commonly resolved by installing the newest drivers from the Wacom site.
