Hi Folks,
I have manually installed the GoZ start Up script in the relevant Max folder. Going from Max 2011 to ZB 4 is no problem. But when I try to go back to Max I keep getting the GoZBrush to Max.exe Application Error dialog that states the following: “The instructions at 0x004060d2 reference memory at 0x00000002 the memory could not be read. Click OK to terminate the program. Click cancel to debug the program.”
Clicking the cancel button to debug does not fix the issue nor does reinstalling the script into the Max Script Startup folder.
Thanks for any help that you can shed on this issue.
All the best,
Alan Yip Choy
