GoZ to 3ds Max - no model appears in 3ds Max! HELP!!
Hi guys,
I have an issue where when I export model from GoZ to 3ds Max - no model appears in 3ds Max. Here is my workflow:
  1. Create PM3D model in Zbrush
  2. Select PM3D model in ZBrush and click GoZ button
  3. 3ds Max 2013 progam starts up, but the model does not appear in the Viewport
While I am exporting, the GoZ plugin appears to be working properly (it even says ‘File Saved to Disk Succesfully’ in upper left hand corner) so I am very confused why nothing is appearing in Max.
Has anyone else seen this happen? Or have any suggestions on things i can try to troubleshoot?
Apologies for the desperation, but I have no idea how to get some help on this!!
Thanks much!
Max
i dont use 3dmax sounds like a flip face or import - export scaling issue check your tool > export options in zb and try importing manually ? if you are successful
importing to max then try goz again you might have to > tool > display properties > double (sided) or flip in zb. also if you do any mirroring faces get flipped or hidden between apps and one app doesnt know what size a model is created in another - sometimes off the scale ?.
