Goz problem: Opens a New instance of Max instead of using existing
Hi Guys
We’ve been having problems with GoZ.
From within Zbrush Goz has been opening new instances of Max rather than use the max scene that’s already open and in use. It also fails to add anything to the new max scene. However we can sometimes still transfer models to Zbrush from Max.
It doesn’t always happen, but it seems to be getting more frequent and more people are noticing this too.
Restarting max and Zbrush doesn’t fix the problem so our only solution so far is to restart our PC’s, which does.
This is happening on our machines at home and our PCs in the studio, so this isn’t isolated to one installation or copy of Zbrush.
Any ideas what could be causing this? as its very frustrating.
Thanks
Can you check, when it happens, if you have one or several instances of GoZBrushtoMax.exe application running?
Most of the time, this issue appears because of file privileges issues, then you should consider doing a manual install. What puzzle me is that it appears randomly on the same computer, right?
