GoZ opening new Maya every time.
Hi all,
I’m having an issue where GoZ opens a new instance of Maya every time I press it from Z4. Has anyone experienced this? Let me know if there is a solution!
-Patrick
Yes, I’m having this problem at work. But I don’t have this problem at home. I’m not sure how to fix it either.
Same here. I’m on XP-64 with Maya 2009. I tried editing the userSetup.mel as described in another thread, but Z4 still opens a new instance of Maya everytime GoZ is pressed from inside ZB, regardless of how many instances of Maya are open already. I’d really appreciate a solution here as well.
Cheers!
Ditto! I just checked this out and I get the same issue. I had problems with the install as the goz shelf did not appear in Maya so I had to copy the shelf script to the correct location. I guess i’ll just not bother with Goz until someone comes up with a fix. To be honest it is just another thing that isn’t working as expected, I have experienced more crashes with version 4 in a few weeks than 3.5 in total, and I have already reinstalled version 4 3 times to try and fix things.:cry:
Works like a charm now on my end. Here’s how it’s solved:
Cheers!
PS: See here for the full thread: http://www.zbrushcentral.com/showthread.php?p=725052&posted=1#post725052
Thank you man, had problems with that for ages! Awesome!
