GoZ not working with Lightwave 11
I have Lightwave 11 and Zbrush 4R3. When using Lightwave and trying to send to Zbrush I get the error . Error in importing object. I tried checking in Zbrush if I need to set up Lightwave connection and Lightwave does not appear in the path buttons or on the list of programs in the Force Reinstall button. Can anyone help?
Thanks
I believe you have to have the goz pluggin installed. I can get mine to work both ways but only from modeler. If I try to send an object from zbrush to lightwave layout, layout crashes every time. So I have to send it to modeler, then from modeler to layout.
Errrrr. Still better than doing it manually.
Wayne.
Mine is workin - for the most part. Sometimes however, going from LW to Zbrush, ZB freezes up and the cursor is a little arrow head with a circle with a Z in it. Anyone seen that?
