GoZ not working in 4r6
I recently upgraded my 4r4 to 4r6 and goZ no longer works. I had used it with no issues previously. Now when I try to get it started, I get one of several problems. Either a warning saying that it cannot run the command to export from zbrush, or it has no connection to maya,or it says I’m critically low on memory and I should delete things such as my trash and documents. I know I have enough memory. I have tried to force reinstall it and I have also completely uninstalled zbrush and reinstalled. I’m becoming very frustrated with it and would appreciate if someone has a solution. I looked around on the internet first, and some people have the same problems but it seems that no one has a solid answer.
The first thing to try would be to go to your 4R6 installation’s TroubleshootHelp folder and run the GoZ installer found there. Most problems with GoZ are related to permissions and this usually fixes that.
Thank you very much, i think that fixed it. :+1:
