Goz not working after changing temp path
Hello guys
I changed my vmem path to an HD where ùi have more room…
But now Goz can’t find the objects to send to other apps, I guess because he’s looking in the old path
How to fix this? thank you!!
p.s. ZB is giving me this messages after I hit Goz : “Unable to save file” and right after “Error while trying to save a file, saving aborted”
Take a look here: http://www.penny-cat.com/wip-blog/changing-the-zbrush-autosave-directories
thank you
but still not solved
I went back to default paths, but nothing changed :
I forced reinstall goz too
Unable to save ztool it keeps saying :frowning:
You say you returned to your old paths but there is only one path stored in ZBrushScratchDiskPath.TXT, unless you did further changes.
About ZBrushScratchDiskPath.TXT changing the path will give you an error unless you create the folder path manually, specially this folder, that is not even mentioned in ZBrushScratchDiskPath.TXT
?:\Users\Public\Documents\ZBrushData\VMem\
Double check that you are not missing any of the expected subfolders that should be inside of:
and create them manually if needed
thank you but didn’t work… I try to do a fresh reinstall
