Hello. I am on Windows 7 and using Zbrush 4 and Modo 401 (32 bit). I have followed all the instructions from Zbrush and installed everything right.
The problem is that I am able to export (by pressing GoZ) from Modo into Zbrush perfectly but from Zbrush when I click GoZ, it says file saved successfully and it opens MOdo but there is nothing in it, Modo opens as a New Scene.
I had followed everything right, the only thing was that I was not able to locate “GoZ_KeyShortcut.cfg” file.
I have also tried force reinstall but with no luck.
Kindly help. Thank you.
P.S. ALso kindly tell me how to change the default GoZ application. I cant seem to change from MOdo to C4D. How do I do that? THank you.
