GoZ Modo
Hi Guys,
I just bought and installed Zbrush, it looks so far so good … but when I push the GoZ-Button in Modo to transport geometry to Zbrush -> Modo always crashes? Even with simple geometry like a sphere or a cube …
OS-X 10.6.8, Modo 601 SP4, Zbrush 4R4 P2
How can I fix that?
Thank you,
Alain
Hi Guys,
How can I fix that?
Thank you,
Alain
Did you first run GoZ from ZBrush to properly set up the GoZ bridge? Until it has been run to send an object from ZBrush the first time, it will not work to send objects from modo.
If you did first run GoZ from ZBrush, then my recommendation would be to try doing a manual reinstall of GoZ. The instructions for how to do so are in your ZBrush 4R4\Documentation\plugins folder.
How can I run GoZ alone? I thought it is an invisible plugin that runs in the background?
The instructions written in the manual don’t help, because they say that you should delete old-config files which should be into the preference-folder of modo … but these files zbrush requires are stored on another place?
If I delete the Camera in Modo and click then on the GoZ-Button, the file is even not transportated but Modo doesn’t crashes anymore?
Pixologic says: ‘GoZ now supports Maya 2013 and Luxology modo 601. (Note: modo 601 on OSX requires a manual update when importing a model.)’
What does this means??
http://www.pixologic.com/docs/index.php/About_ZBrush_4R4
