GOZ Maya Issue
Hello,
I am having an issue with GOZ and maya. I start out by sending over my model through GoZ from maya to zbrush and everything works fine. The issue is when I try to update the maya version of the model by hitting the GoZ button in zbrush.
Instead of sending my updated model back into my existing scene it opens up a fresh copy of maya with only the model I was working on in zbrush. Am I doing something wrong, is this a bug, or is this just how GoZ works?
Thanks
Adam
I’ve got the same problem. It is not supposed to open a new Maya scene. I found some solutions for older maya versions but I don’t think they work for Maya 2014 and Zbrush 4R6. Would really appreaciate if anybody could help.
Make sure that both Maya and ZBrush have the same “Run as Administrator” status. If one program is set to run as administrator, the other must be as well.
To check on the program’s status, right-click on it and choose “Properties”, then go to the Compatibility tab. At the bottom of that tab you’ll find the check box to always run the program as an administrator.
Generally, ZBrush should not be set to run as administrator. But if you use GoZ with another program that requires that setting, you will need to set ZBrush to be the same way.
