GOZ max to Zbrush Subtool bug...
hello
I’m having a problem with subtools and going from Zbrush to Max.
When I do Goz All and then it opens it up in MAX I can see that max is importing each subtools but once it’s done, only the subtool at the end of the list (in Zbrush) shows up in max.
Where is the rest?
I have this with many scenes.
Thanx
h20
Have you tried the GoZ update? I was having the same problem with Max 2011, but after installing the latest GoZ it works as expected.
-m
Several objects with the same name ?
no the update didn’t do anything, that is why I came here and posted.
All objects have different name
