Goz import scale problem
Hi guys i hope you can help me :
GOZ in Zbrush is great, i was using it with max 2012 and the scale was correct, but now when i use GOZ with max 2014 ( zbrush 4r5 ), the scale of the imported object is very very BIG ! when i import the model normally without GOZ in zbrush the scale is correct !
So any help here to fix the GOZ import scale ?
I’m asking this because i want to use the subtools import with Goz since i have multiple objects to import at the same time, since the default import in Zbrush doesn’t do it in subtools :s ( if i’m wrong can you explain to me ).
