GoZ: How to pick the preferred 3D app (between 2 or more) to link/connect?
Hello,
I have 2 3D apps (Maya & Modo), & set path in GoZ preference to both.
Now, how do I pick which 3D apps I wanted to link using GoZ?
Right now, it default to one of the 2 I have (Modo).
i.e GoZ always open Modo when I click ‘GoZ’ in Zbrush. I wanted to be able to toggle GoZ between Maya & Modo base on situation.
Any help will be appreciated.
Thanks.
http://docs.pixologic.com/user-guide/zbrush-other-programs/goz/target-applications/
From I’m aware the only way to change the GOZ target application is with the small icon “R” near to GOZ buttom or the shortcut alt+ctrl+g that will reset the current application target for GOZ and will give you the option to change to another one.
Thanks a million!
I knew the mistake I made earlier. I press the ‘R’ key on the keyboard! :lol:
