[GoZ] Geometry doesn't appear in Zbrush, after imported from 3DS
Hey guys,
I’m new to this Forum and Zbrush in general and hope that I didn’t do some stupid mistake.
Like I said in the title, the Geometry just doesnt appear in Zbrush. I can’t draw it into the canvas either. Any ideas how to fix it? Here are some screenshots that show my situation more or less.
Greetings! :slight_smile:
Have you tried pressing ‘F’ to frame the mesh?
I just tried. Didn’t work.
Try in Tool>Display properties> Check double. Then press F to frame the object. If that is the case. Then your faces are flipped normals during the import. If need to fix that you can Click on Flip next to the Double and all faces will be flipped
Thanks. It worked. Didn’t realize they were flipped in 3DS!
