Hey all,
I have a model that I built the base mesh in Maya, used GoZ to take it into Zbrush. I have since sculpted on it and saved in increments. Now when I try to use GoZ to take it back to Maya I get an error message (posted below). If i go back and use a very early mesh it works, later versions do not. I have added some items to the model with zspheres and they transfer to with goz ok as long as they have depth.
here is the error message i get in the script editor:
// Warning: Errors have occurred while reading this scene that may result in data loss.
Please check the Script Editor for details. //
// File read in 0 seconds.
select -r female_testmesh5 ;
displaySmoothness -divisionsU 0 -divisionsV 0 -pointsWire 4 -pointsShaded 1 -polygonObject 1;
subdivDisplaySmoothness -smoothness 1;
select -r female_testmesh2 female_testmesh5 ;
doDelete;
// Error: file: /Users/Shared/Pixologic/GoZ_Projects/Default/female_engineer1.ma line 71: Error reading data element number 1: na //
// Error: file: /Users/Shared/Pixologic/GoZ_Projects/Default/female_engineer1.ma line 73: Error reading data element number 1: na //
// Error: file: /Users/Shared/Pixologic/GoZ_Projects/Default/female_engineer1.ma line 75: Error reading data element number 1: na //
// Error: file: /Users/Shared/Pixologic/GoZ_Projects/Default/female_engineer1.ma line 77: Error reading data element number 1: na //
// Error: file: /Users/Shared/Pixologic/GoZ_Projects/Default/female_engineer1.ma line 79: Error reading data element number 1: na //
// Error: file: /Users/Shared/Pixologic/GoZ_Projects/Default/female_engineer1.ma line 81: Error reading data element number 1: na //
// Error: file: /Users/Shared/Pixologic/GoZ_Projects/Default/female_engineer1.ma line 83: Error reading data element number 1: na //
// Error: file: /Users/Shared/Pixologic/GoZ_Projects/Default/female_engineer1.ma line 85: Error reading data element number 1: na //
// Error: file: /Users/Shared/Pixologic/GoZ_Projects/Default/female_engineer1.ma line 87: Error reading data element number 1: na //
any thoughts on this?
THank you,
Doug
