GoZ error when going from Photoshop to ZB
Hi
I finally set up GoZ, and it seems to work with Modo. However, I receive error with Photoshop. I am able to send file to Photoshop, but when sending file back to ZB from Photoshop I receive an error regarding a missing executable routine.
This is the trouble file:
[FileExecute,gGoZDLLPath,GetFirstObjectTextureFileName,"",0,gGoZTempMem]
I have tried force reinstall GoZ through ZB…but still get the error.
I greatly appreciate help.
Hey talos,
I’m having the same problem. Just wondering, did you ever find a solution to this? I’ve been searching around with no luck. Tried to force re-install through ZBrush and also manual re-install, but I’m still getting the error message.
I can get from ZBrush to Photoshop, but not from Photoshop back to ZBrush.
Any links or advice is greatly appreciated!
Thanks!
