GoZ Error, Urgent Help Please
Hi, I have been working with Zbrush and 3DS Max for a while without any problems using GoZ to transfer over my work, however for some reason after attempting to send over a piece from Zbrush to Goz I get the error:
TAMPLATE ERROR
Specified export tamplate can not be found file export canceled.
This then goes and the next error appears:
script: goz.txt, error:tool:export:scale, in:[IGet,“tool:export:scale”]
I have tried removing the files, re downloading GoZ and re installing however I still get the same errors and is extremely irritating as exporting the piece and importing into max adds a large amount of polygons and with my university unit requiring a poly budget it is not viable.
Using Windows 7, Max 2012, Zbrush 4R3
Thanks in advance
you are in 4R3 and actually is 4R4 2P, probably you may want to update…
