GoZ does not ask which app to send to.
ZB 4R6
Want to send mesh to photoshop. Plugin is installed, press GoZ in ZB and it starts max up even if photoshop is open. Any ideas? The docs say a dialog will open to ask which app to use,… never seen it.
Cheers
Document menu ZappLink may serve you better. Or else you have to pick the application for GoZ which I believe is more for 3D objects and apps like Max, Maya etc. http://docs.pixologic.com/reference-guide/preferences/goz/
Thanks Doug!
Man are you quick :slight_smile:
Yeah I was not able to pick the application it just started max by default even though the paths were specified and the app plugs were also installed. Redefining paths didn’t work either. Starting the app via the troubleshoot folder in the pixo root folder worked. Goz for photoshop looked a little weird :slight_smile: I tried zapplink like you suggested and it blew me away, problem solved.
Cheers and thanks for the fast response.
You can change the default GoZ app by pressing the ‘R’ button to the right of the GoZ buttons.
Ha ha!
Never noticed that one and must have missed it in the docs. Thanks Marcus :slight_smile:
