GoZ doens't work properly
Hi there,
I’ve been messing around with Zbrush 4, especially looking forward to GoZ that would make my life alot easier… if I could get it to work :slight_smile:
I’ve read up on the documentation about the workflow, and although I seem to be doing it correctly, I’m not getting the promised results.
I’ve set up a path to 3dsmax, and when I’ve created UV’s, normal and displacement map, then hit GoZ ‘Visible’ it only transfers the selected mesh to 3dsmax, ignoring all other visible subtools ánd most importantly, all my created maps.
I was under the impression GoZ would automaticly set up all the created maps in 3dsmax? I also tried cloning my maps in Zbrush… same result.
Any ideas? :confused:
I had to use the UV-Master Tool for creating UVs - then it worked in 3dsmax 2011 Design
Hmm nope, didn’t work for me :frowning:
GoZ is supposed to automaticly create a material with the correct maps in their slots, right?
Here we go :slight_smile: http://www.youtube.com/watch?v=XrkQKW48NrE
