goZ automatically reset import flipY setting
I have a face created in max, imported in Zbrush with Import Flip Y setting enabled.
After reinstalling my zbrush (computer change), this setting is disabled by default. So When I GOZ import the head in max, its flipped.
The problem is : even if I enable import/export flipY, Goz automatically reset this setting during the export process…
is there a way to make sure Goz keep the import/export setting?
Okey zbrush seems to do it automatically on every computer, my probleme might comme from something else…
Yes, GoZ is using its own settings, the if you change themin the preferences, GoZ won’t use them and no way to change that…
The probleme came from a old GOZ version.
Installing the latest updated solved it.
Thx to Paul Gaboury!
You are still using ZBrush 4.0 or one of the last beta, not the 4R2 commercial version?
