GoZ and UV Master friendly meshes
Hi
I find that using GoZ and UV Master with my meshes is a bit of a hit-and-miss. Some meshes export and unwrap fine. Others just don’t. The error reports are pretty random and unconvincing…
e.g you export one sub tool with GoZ and it all works well and good
you try it with the next sub tool and it says “Unable to open file in folder” or permission error…really?? on this particular sub tool only?
So what are things to avoid in a mesh to make sure that is works fine with GoZ and UVMaster?
Thanks
El
