GOZ and 3dsmax 2018 still broken
Zbrush 2018 is still broken when sending models to 3dsmax 2018. It’s more than one year that the problem is there. Please fix it.
Specifically, when you start Zbrush goz works for the first time than the link between applications breaks and Zbrush opens duplicate instances of 3dsmax. Very annoying.
There is a partial workaround here, and I mean partial, but at least you can send forwards and backwards from both programs:
https://forums.autodesk.com/t5/3ds-max-modeling/goz-opens-new-instance-of-max/td-p/7284116/page/3
Thanks Altea. you’re a life saver. I’ve written to the support about the problem two times and they’ve said that they can’t say nothing due to company policy. Basically it means we have to use the program with an unresolved bug.
Good you have written anyway. More awareness for them we need a solid solution for the GOZ of the most usual 3d generic package, together with Maya.
