Goz after resuming of work
Hello,
I’d like to do something like:
  1. Make TPoseMesh from my original ztool.
  2. GoZ my TPoseMesh to max and use bones for pose it.
  3. GoZ back to zbrush
  4. finally TPoseMesh -> SubT
Ok, it works but if I close 3dsmax and I’m in step 2) I cant GoZ it again. I mean it’s imported but as new tool. So if I try to TPoseMesh -> SubT I have information: “Please Select TPose Mesh”.
If I save as obj from 3dsmax and try Import to TPoseMesh tool and then I do TPoseMesh -> SubT it works but whole mesh has artifact because when it’s saved as obj it’s just new mesh.
Can I somehow force GoZ from max to use TPoseMesh as that one which will be changed with this from max? I mean after zbrush and max is closed?
Please dont tell me that I have to do at once.
Wow I did it actually. I can export mesh as obj from max and import it replacing TPoseMesh but I have to select zbrush preset while exporting. I opened .obj file and there is slightly change inbetween if I save it as standard .obj, or .obj for zbrush.
