Goz --> 3ds Max wont work!
Hi!
I’m having trouble with Goz and 3ds Max. It has worked before (ZB4, I think). Now I have ZB4r4 and I can’t get it to work.
If I load up say the Rhino project and simply press Goz button, Zbrush will think for a second and say “File saved to disk successfully” and then nothing happens. It behaves the same whether Max is running or not.
I have tried “force re-install” from Goz preferences and looking up Max’s path again, but nothing works - what am I missing?
I’m running 3ds Max 2011 x64 and Goz has worked before on this same computer.
Make sure Max is closed.
Preferences in zbrush/Goz/redefine path to max
See if that works. Has for me a few times
Thanks,
I have done that, but apparently the problem is that I had both applications using administrator rights - it seems to mess things up with the GoZ setup.
