I’ve been browsing the tutorials forum for a good step bt step tutorial on head sculpting but have’nt found any. Youtube has lots of videos but they are all too fast to tell whats going on and there is no commentary. Also most of the time you can’t see what brushes and settings they are using. I have tried lots of different approaches like starting with a Zsphere,Polysphere, or Squirkle and it always ends up looking like a third grader mangling a ball of play-do! Maybe I just don’t have an eye for sculpting. If I can find a good starting point maybe I can get better but for now it seems i’m getting worse instead. A really thorough tutorial that explains how to get started and the brushes and brush settings would help me get better. Maybe someone has come across one? Thanx for any help.
If you’re looking for comprehensive tutorials with audio and high quality resolution so you can see every little thing they’re doing, you’re most likely going to have to shell out some cash for a DVD.
Gnomon Workshop
http://www.thegnomonworkshop.com/store/category/12/ZBrush
Digital-Tutors
http://www.digitaltutors.com/store/home.php?cat=29
KURV Studios
http://www.kurvstudios.com/zbrush/
db
Thanx Dustin…I don’t mind spending some cash as long as I can get what i’m looking for. I did finally find a set of tutorials that I may be able to get a handle on. They were on the tutorials forum… “Black Guy” is what it was called. He is not doing alot of sculpting really…more using the move brush and tweaking the edge flow. I guess you could say it’s a hybrid of what i’m used to doing in Max and Zbrush. Thanx for the links…I’ll check them out…
