Hello regtel305,
there is no punctuation in your previous message, this is outrageous!
I think you are near the solution to use GoB, try to read again the documentation and redo the whole steps, maybe it will help you?
Hello regtel305,
I have a same problem as #107.
I have used this addon but after updating my blender v2.65a to v2.65, the addon got unable to tick.
I deleted addon files and retried setting up following Stuntonâs document but it didnât work.
I cannot find any massages on Python console.
This addon is useful so Iâd like to use again but I couldât figure out how to solve this problem.
Does anyone have some advises?
Mac OSX 10.7.5
Zbrush4R4
blender v2.65
GoB_addon_263_MAC.zip
I found error messages were showed in console.app.
Bad magic number error is occurred when version of python is different from one used to compile.
I think ext_GoB.pyc must be compiled with python 3.3.0. But I canât get a source code of ext_GoB.pyc, right?
12/12/13 22:19:34.624 [0x0-0x62062].org.blenderfoundation.blender: Traceback (most recent call last):
12/12/13 22:19:34.624 [0x0-0x62062].org.blenderfoundation.blender: File â/Applications/Blender/blender.app/Contents/MacOS/2.65/scripts/modules/addon_utils.pyâ, line 264, in enable
12/12/13 22:19:34.624 [0x0-0x62062].org.blenderfoundation.blender: mod = import(module_name)
12/12/13 22:19:34.624 [0x0-0x62062].org.blenderfoundation.blender: File â/Applications/Blender/blender.app/Contents/MacOS/2.65/scripts/addons/GoB_addon_263/init.pyâ, line 20, in <module>
12/12/13 22:19:34.624 [0x0-0x62062].org.blenderfoundation.blender: from . import ext_GoB
12/12/13 22:19:34.624 [0x0-0x62062].org.blenderfoundation.blender: ImportError: bad magic number in âGoB_addon_263.ext_GoBâ: bâl\x0c
'</module>
Hello seijik,
the init.py file try to import the other file but it doesnt work.
This error may occurs when you have installed a differnet version of Python.
This script do not need Python because it use only module provided with Blender.
If you have installed Python and dont use it you can uninstall it.
If you use Python you can install the same version used by Blender (Python 3.3.0) (or check env var)
Iâve been using GOB on the Mac (10.8.2) with Blender 2.63 and with 2.64a. Now with 2.65 I too canât tick the box in the blender preferences to activate GOB. I do not have any other installations of python. Zbrush settings for Goz is set for Blender 2.65. I donât see any errors in the python console window in Blender or in the Mac Console app. Please help.
Update -
tried restarting blender - still couldnât tick
tried restarting computer - still couldnât tick
Thank you for replying Stunton! I have installed Python 3.3.0 and set my /usr/bin/python to symbolic link of python 3.3.0, but still not working.
If you donât mind, I want to try with not compiled source of ext_GoB.pyc. Can you open .py code?
>dougt
In my case, I can see errors in Mac Console app, so your problem maybe different from my one.
You are right the problem is the compiled file!
Blender 2.63 and 2.64 use Python 3.2, not Blender 2.65 (Python 3.3).
Yes of course, you can find it in this attachement with the version updated for Blender 2.65
edit : I have updated the addon because it missing the window menu (for fullscreen and Blender console).GoB_addon_265a_WIN.zip (239 KB)GoB_addon_265a_MAC.zip (239 KB)
Thank you Stunton! your addon works perfect!
I cannot do my work without this
Thank you Stunton, I waited for that!
Thx a lot man!
This is such a useful tool, thank you for keeping it updated as well. Do you have any updates to this addon for the recent Blender release? Its still working, but Iâm getting trackback errors now.
Do you have an example of the error?
Thanks for the great plug-in!! I have it working on OSX and Blender 2.65. I was just wondering if anyone knew of a way to preserve skinning/weighting when bringing a mesh back from Zbrush? I want to make mesh tweaks to a skinned/weighted mesh, but I am lose the skinning/weighting when I bring the mesh back to Blender.
Hello operator23,
You cannot avoid skinning to be lost, so you need to use one copy and the âCopy Attributes Menuâ add-on (File->User Preferences then âAddonsâ tab and search for âCopy Attributes Menuâ addon).
For the copy, you can do it after lost the skinning:
Now you can use âCopy Attributes Menuâ addon to copy skinning between the old mesh and the new one.
Select the new object (without skinning) then select the (with skinning) and press Ctrl+C to display the copy menu.
Select âCopy Vertex Weightsâ, et voilĂ .
Hi,I use blender2.66 and zbrush4 r5,but I can only send the model to zb, can not come to the blender, whether because the version is too low, what can you update"gob" , thank you very much!
Hello, in Blender you have to click on the Blender icon near the zbrush icon to import the files.
Thank you very much! ! !
Hi, my problem is when I try to export from Blender to ZB. To get the object I have to Import it manually in ZB from the GoZProjects/Default folder.
I was reading the thread and found (#85) that the addon uses GoZBrushFromApp.exe from:
C:\Users\Public\Pixologic\GoZBrush\GoZBrushFromApp .exe
I searched the mentioned file in my folders, but the only files that I found similar to this were:
- C:\Users\Public\Pixologic\GoZBrush\Scripts\GoZBrushFromAppScript.zsc
- and the other are .txt or .zsc
In the System Console the message says that it does not recognises the .exe file. (Because there isn´t one)
How can I solve this to get it right?
Thanks Stunton for the addon!
Hello Omar,
it is an installation problem of GoZ.
ZBrush/GoZ create this files during the first configuration of GoZ.
Try to install the update 1 of Goz and follow the pdf files (GoZ Update 1 pdf then GoB pdf).
That worked!
Thanks again Stunton.
ps. I thought ZB4R5 had the latest and greatest :D. But in this case you have to download and reinstall the GoZ plugin from Pixologicâs Donwload Center. Be sure to select the button/menu âShow plugins for ZB4R2â because the ZB4R5 menu does not have plugins to download due that this version includes all the plugins.
