i am looking for the glow material and can not find it anywhere in my zbrush 4.7 . is there a place i can download it?
You should have a ColorizeGlow material in the Standard Materials section - it’s colored yellow. But note that you need to use Best render for this. You can press Best before BPR to combine the two renders for a model in Edit mode.
i finally the colorizeglow but it was more of a white color, but when i applied the material to my mesh it turned it black and i couldnt change the color of it to what i wanted
You can change the color in the S1 tab of the Material Modifiers. And the color will remain black until you use Best render.
ok ill try that. thanx
