Gizmo
Hi there,
I’m fairly new to Zbrush, coming in from max. I was wondeing how to get the gizmo up when you are rotating or moving in v3.1? In most tutorials, people have a gizmo, but in mine i only ever get the action line or whatever it is.
Thanks,
GBizzle :smiley:
If you’re in Edit mode and activate Move, Scale or Rotate you’ll get TransPose. If you’re not in Edit mode, you’ll get the gyro. So simply press T to exit Edit mode and then immediately activate the gyro mode that you need.
De-select “edit” and “draw”, then select either "move, “scale”, or “rotate”.
