Anyone else experiencing a ZBrush crash when Gizmo gear is active using at least a couple of the Deformers. Opening Zbrush and selecting Polysphere. Deleting lower sub div’s and deactivating symmetry. Activate Gizmo and then activate the Gear, select Project Primitive. Don’t move Gizmo and just wait for QuickSave to countdown. When the QuickSave has counted down ZBrush crashes. I tested this with the Taper Deformer and crash occurred with it as well.
I tested it with the Polyshpere with symmetry on and lower SubD’s to level one and delete higher. Gizmo and gear active, Project Primitive on. Allow QuickSave to to countdown and ZBrush crashes.
I tested Polysphere as mentioned in the first paragraph the only change was moving Gizmo until the new primitive is showing and projecting from the Polysphere. Then Allow the QuickSave to countdown. No Crash.
I loaded the FemaleHead subtool and tested Gizmo again as in first paragraph, no crash.
I loaded a cube primitive converted to Polymesh and tested Gizmo again as in first paragraph, no crash.
