Getting rid of Alpha Border?
I am using Alphas to add displacement.
How do i get rid of the Alpha Border?
i have set the Radial Fade up to 20, but still have this issue.
is there another setting i need to change?
thanks!
ha! i just came here to ask this exact same question.
try turning the zintensity way down.
most times I don’t need it higher than 5 but it depends on the mesh and the alpha so some experimentation will be necessary to find what works for you.
oops forgot one…also try various focal settings.
thanks for the reply aminuts.
i ended up opening the alpha in photoshop and painted a feathered border around the image (black or white depending on the image) which seemed to do the trick.
the RF slider in the alpha palatte will allow you to feather the edges on the fly.
S
