Getting IntQuaRay error message
HI I really need some help everytime I try to generate a normals map using zmapper with it default settings I keep getting this message Plugin note: memory could not be allocated (IntQuaRay)
I also check my Preferences-Mem-Compact mem it set to 256
How much RAM does your system have? How many polys does the model have?
For ram I have three Gigs and the low poly count model I imported from Maya is all little over 84 and the high poly in zbrush I am not sure i now I multiplied it 8 times the only issue i have is when i try to extract the normals map.
That’s when I get that message, also I noticed it said that the bump mapping is not activated how do I activate it
As of ZB3.1, you don;t really need this feature. A neat trick that I use is painting a bump map in ZB, export it, and with Xnormal I can integrate it into my Normal map in Photoshop, using Overlay mode…
Then lower the opacity until the map looks satisfactory…
hope that helps
