I noticed something disturbing in the last update of ZBrush. My hd geo is define by default in the preferences to 10 millions.
When i push A to enter into HD geo mode it never show me more the 3 millions poly… even if i crank up the max poly in the preferences to 15 millions… I used to be able to chose in the preferences how much HD geo I could see, at list it was like that before. Now it’s seem to be lock to 3M or less .
I’m working on a ride; it’s a very big scene and I’m using the Nick Zuccarello HD trick… https://vimeo.com/9673644
But if you can only show 3 millions poly or less in HD (without knowing how much poly zbrush will chose to show 800k, 2M, 1.2M???) at a time it’s a real pain to split you model in polygroup.
Is there a solution? A work around? A P3 coming soon to correct that and other stuff?
It’s badly needed for me to have an answer it’s kind of an job blocking issue…
