Generate Displacement From A Different Mesh?
Hey guys, is it possible to generate a displacement map from one high rez mesh onto a completely different, lower rez mesh?
What I mean is, basically I have a high rez mesh built in Zbrush, and I have a lower rez mesh built and UV’ed in an external program - can I generate a displacement map form the higher rez model onto the lower rez one? I understand how to do it if it’s the same model, with different subdivisions, but can’t find a way to project it onto another mesh.
(I’ve found it pretty easy to do in Mudbox - basically point to your low one, then your high rez source and then voila!, but can’t find an equvalent in Zbrush - I could do it in that, I guess, but I prefer to keep it all in Zbrush :slight_smile: ). Any ideas?
See here: http://www.zbrushcentral.com/zbc/showthread.php?t=64410
