Generate a Bump Map - How?
Hi All,
A noob question here. How do you create a bump map in Zbrush 3.5 R3?
Thanks for any help.
If you want to create a bump map instead of a normal map http://www.pixologic.com/docs/index.php/Painting_Bump_Maps
Richard
Hi Richard,
Thank you for replying. However, I see there’s a button under Displacement Map tab with the name Mode. Depending if this button is turned on or off, ir creates the bump map or displacement.
Is this the same as the Brush Bump?
Thanks Richard.
