Gagged edge with Zprojection?
Hey, im having some problems with the zprojection, when im using the tool it is very smooth and how i want it, but when i drop it onto the model the edges get really gagged. i was wondering if this is fixable?
Im using photoshop custom vectors to create the design, just incase you needed to know.:rolleyes:
what size is the alpha you’re using? if it is very large then you’ll need to add a gausian blur to the edges of the object so it knows how to handle that edge.
It looks like the model just doesn’t have enough polygons. If that’s the case, then nothing you do to the alpha will give you a smoother edge. You’ll need to divide the model again. Looks like a few times.
aurick is right.
I know your mesh has 5.6 mill or whatever it says at the top…but not that many on the side…they are all being taken up somewhere else in the model.
You can always split that piece into subtools and then subdivide the parts that you need the extra resolution.
Ok i will do that thanks for your replies :smiley:
