Freelance: Highres charactor modeler needed
I’m in the need of a highres modeler for a freelance job - your task will be to model a statue with accuracy and detail in mind. I can’t show anything yet as the photos has to be taken, but you can have a look at provided links to get a clue:
http://z.about.com/d/dc/1/0/j/LincolnMemorialStatue.jpg
http://www.seeing-stars.com/ImagePag…sStatue1.shtml
http://www.jeffersonhistoricalsociet…rsonStatue.JPG
These pictures gives a good idea about the overall look and amount of detail I’m looking for - just to make it more clear, I can add that I’m not interested in this style:
http://www.bartellonline.com/shangha…lai_statue.jpg
http://thesims2.simshost.com/images/…ton_statue.jpg
Both are too clean and lack that old statue/hand crafted feel to them.
The model have to be in LWO format, however you may use ZBrush - in which case I will need the ZBrush project file as well - If working in ZBrush, then it’s important that the model is Lightwave compatible: working UV’s and displacement map for lowres version.
The model will need to have a fixed (sitting) pose - no need to prepare it for rigging or any kind of animation at all.
This is all the information I can provide atm. If interested then feel free to send me an e-mail, telling me what you expect in return, and how much time you would need to work on the mode - you can base it on this: http://z.about.com/d/dc/1/0/j/LincolnMemorialStatue.jpg
Your quote and time estimation will of cause only act as an indication to get things rolling.
I will need to see at least 3 highres and realistic charactor modeling samles from you with shaded/rendered and wireframe views.
hi…i am a freelance modeler…i will get u one model in 2 days…i use zee brush and maya…i will expect 300$ per model…u can cheakout my work at http://www.cgtantra.com/forums/showthread.php?t=7219
u can mail me at…([email protected])
id be up for a challenge… if u still need someone
www.wrightsonstudios.com
my website with some of my work
you can email me at [email protected]
I have found what I was looking for - thanks for the interest.
