frame object on canvas bug (alt+click)
Many others in my company and I have the problem that Zbrush frames the current subtool on the canvas when we’re sculpting with alt pressed. This is incredibly annoying, especially when we’re sculpting on details etc. We have that problem since 3.5. somebody in the forum wrote we should set click distance and click time as low as possible which helped a bit. It’s still happening for some reason but not that often anymore.
The problem in zBrush 4 is that many shortcuts aren’t working when clicktime and distance is very low. For example invert masking(ctrl+click on the canvas) or unhide all(ctrl+shift +click on the canvas) etc.
Is it possible to disable the frame shortcut (alt+click) or do you have any other ideas how to fix this?
Hello Cral
You would actually want to turn up the distance or time not lower. You can disable the alt framing by going to Preferences>Edit>Auto Select Subtool.
This will also disable the ALT+click on a subtool to select it live on the canvas. If you don’t use that feature then it will be all good for you.
Paul
